jatleson
- Oct 21, 2018
the E badge will work but the pegs arent exactly the same , just cut them offAre there any rear emblem replacement options that use the holes from the OEM KIA badge? Not looking for covers that go over the OEM, true emblem replacements. The front emblems have the pegs to align with the factory holes.
there are not. what do you need the pegs for?Are there any rear emblem replacement options that use the holes from the OEM KIA badge? Not looking for covers that go over the OEM, true emblem replacements. The front emblems have the pegs to align with the factory holes.
Easier alignment and more secure adhesion. Not mandatory, but it would be nice.there are not. what do you need the pegs for?
also keep in mind that if you're using the Stinger script on the back, it will not be perfectly centered because you have to use the letters to cover the holes, you can't tell by looking at it though.Pegs don't make them more secure. Alignment is simple with a bit of painters tape or, as stated, dry erase markers.
That is the route I'll likely do. Did you use OEM for both front and back with the needed pegs removed?
