RaceChip Installation Guide
EDIT:
The correct installation guide is the one with a Turbo GDi engine cover in Step 2 of the instructions.
The installation guide with the VW cover is a generic one.
Just an FYI - but if we upload a new attachment for every discussion - we'll need to update every one if/when there's a new version. And that's IF we find every mention of it. It will be better to host the PDF in one spot. I've updated the link in the first post - as well as the other mentions of the new installation guide today. Let me know if and when the document changes and I will keep it updated on the server:
https://stingerforum.org/racechip-installation-guide.pdf
Dumb question - for the regular Racechip S(Sport), number 5 is the highest mapping? In GT and GTS versions 5 is factory stock.
Yes, but the software of map 5 of the S is not identical to map 5 in the RS. Also Map 6 in the RS is different from map 6 in the GTS.
Quick question. The installation guide for the 3.3T has the RaceChip module located/mounted on the fuse box. How exactly would you go about mounting it there and/or has anyone mounted it somewhere else?
Hello David, please note that there is an installation video on YouTube:
