Older software versions - Stinger GT 2018
Dragon19
I am looking for an older version of navigation software for the Stinger 2018 CK model.
I am interested in a version below V136, e.g.:
CK.USA.SOP.V091
CK.USA.SOP.V108
CK.USA.SOP.V115
CK.USA.SOP.V120
CK.USA.SOP.V123
etc.
I need the entire DAUDIOPLUS folder with the update file, the system does not accept version V140 and I want to install any lower version to check if it will work.
I will be grateful if you share or indicate where I can download the older version.
I don't think that what you want will work. Everyone who has tried to reuse an SD card with the previous navigation version has had no success. Apparently, when you update. there is no going back.
I have the CK.USA.SOP.V091 version on the radio.
When updating to version V140, I have errors, so I want to update to a lower version than V140 but higher than I have, e.g. V100, V120, etc.
The software files should be on the SD card, I need the complete DAUDIOPLUS folder.
Try contacting hyundai/kia support. They were very helpful when I had nav update failure on my hyundai.
Dont want to get off topic here, but you can downgrade in engineering mode. However it breaks voice recognition.
I've got CK19.CAN.SOP.V133.221006.STD_H stashed away but I doubt you want Canadian firmware. DAUDIOPLUS is 2.11GB and the first folder is "can" so I dont think it'll help you.
If anyone else is reading this, check your Downloads\NaU folder for OP.
Thank you, but you have a different version. You have CK19 and I have CK.
I don't want to do a downgrade but an intermediate update:
CK.USA.SOP.V091 -> CK.USA.SOP.V140 = Not working, errors during update
I want to do e.g.:
CK.USA.SOP.V091 -> CK.USA.SOP.V120 -> CK.USA.SOP.V140
That's why I need lower software than V140.
That's right, the downloaded software may be on your computer: Downloads\NaU\
I only need this folder: DAUDIOPLUS
