OCC with Injen Intake
RKBama
Hey was curious if the Injen Intake will fit with the default mounting bracket with the ADD W1 V3.3 - Baffled Dual Inlet Oil Catch Can Kit .
Thanks for the help!
It can be done, but isn’t strait forward. The ADD W1 dual inlet is a pretty ineffective catch can design, if you still have time to return it, the other catch can designs connect with the Injen without fuss.
I started with the ADD W1 and upgraded to the Sxth Element.
It can be done, but isn’t strait forward. The ADD W1 dual inlet a pretty ineffective catch can design, if you still have time to return it, the other catch can designs connect with the Injen without fuss.
Beautiful setup! I have the SXTH Element Dual Can kit on the way and have the Injen intakes. Did you have to trim hoses or use ones that were not included?
Thanks bud!
The hoses that come with the Sxth Element are plenty long, but I ended up using the small OEM hose in the spot I have circled. It was previously trimmed to get the Injen to fit. Only thing I did that was not included with the kit was ad extra worm gear clamps at every hose junction (and the coatings of course).AEEE5257-6DDB-451C-ADC0-F703F86F5079.webp
Thanks bud!
Awesome, thanks for the info!
