I decided to bleed/flush my non-Brembo brakes today because the car was built two years ago.
Manual says brake fluid capacity is 0.42 quart (395 ml) of DOT 3 or DOT 4 brake fluid. I bought two 32oz (1qt) bottles of Walmart Super Tech DOT 4 brake fluid at about $6 per bottle. I ended up using about 1qt to flush.
I used the Motive brake bleeder model 0107 for Ford/Asian cars. The 0107 Motive adapter will fit onto the brake fluid reservoir. Make sure you use the thinner o-ring that comes with the 0107 adapter. Old school pump and bleed will work too. Some notes:
KGIS calls for bleeding the electronic stability control (ESC) unit by activating the ESC/ABS pump with KDS. Since I don't have KDS, I didn't bleed the ESC/ABS unit.
- Front and rear wheels needed to be removed before I could access the bleeder valves.
- KGIS says bleed order for non-Brembo brakes is Rear Right / Front Left / Rear Left / Front Right.
- The brake bleeder valve nut size is 10mm front and rear.
- A 1/4th inch inner dimension (ID) tube will fit over the bleeder valve front and rear.
