Hey guys. I’ve had my Stinger GT2 since February and have 29k miles. Today when I tried starting my car, it instantly started to bog down in idle and the check engine light came. The car really wanted to die on me. Checked the JB4 app and it said “Error getting JB4 firmware version. Defaulting to "Other".” I thought it was odd then I plugged in a OBD-2 and the issue says
Manifold Absolute Pressure / Barometric Pressure Circuit Low. I assume I either need to take off the MAP sensor and clean it or replace it depending what happens. My real question is would the JB4 not be working if the MAP sensor is bad? And my other question is if my diagnostic of the car is correct, why would a 29k mile car have a fault in the sensor already?
