Limp mode
Shakesbeard
I have done quite a bit of searching, digging and hunting. So my car has a sporadic stutter immediately followed by a P061B code and limp mode. Sometimes it does this a few times a day, sometimes it doesn't do this for weeks. Usually I just clear the code and it fires right back up. Today not so much.
It shut off and I pulled off onto the shoulder. Press start, it starts, dies immediately. Repeat process for about 5 minutes, occasionally it will bounce an idle and die, other times just immediately off. The last start I managed to feather the throttle and get it to run for about 45 seconds, but it sounded like it was only firing on about half cylinders, then it died and also threw an IAT code. I cleared them and it fired right back up and ran fine. Got me to work and ran smooth as can be.
Now with that said, I did research before posting. I checked all of my intake system and found no lose clamps, nothing unseated, nothing out of place. I do have Injen intakes, catless midpipes and an MBRP exhaust. Along with the JB4 and EWG wires. I checked all connections from the JB4 and all are seated and I made sure my firmware is up to date.
This happens no matter the map. Even in map 8. So I am stumped at this point. Do any of you all have any ideas for something else to check? Any other insight?
