KDMRacer.com | HKS KIA Stinger 3.3T Dual Blow Off Valves and Adapter Kit
KDM Racer
Authorized Vendor
Blow off Valve Kit Includes:
  • (2) HKS Blow off Valves (Silver or Black.)
  • (2) Torque Solutions HKS adapters with O-rings
About HKS Blow off Valve
The HKS Super SQV4 limited Sequential Blow Off Valve is the latest from HKS, which uses a unique sequential valve structure and a differential pressure control system, which allows for a broad operating range from low boost to high boost
Its Pull-Type relief design ensures stable operation regardless of the amount of boost pressure
The Super SQV will support new generations of turbocharged vehicles
Super SQV4 features include a black color finish and a nickel-plated, die-cast metal secondary valve, which is swaged to the primary valve, a stainless steel C-Clip, and spring to increase sealing and durability
To assure buyers that they are purchasing an authentic HKS product, the new design incorporates a holographic HKS logo on the back of the valve, as well as additional HKS logos cast onto the body structure
Features
  • High Quality Aluminum Die-Cast Body - Combines the ultimate in looks and durability in the engine compartment.
  • High Stiffness Metal Die-Cast Valve - Reliable operation
  • Triple Fin Design - Triple Fins set at the center of the funnel produces a dynamic and aggressive sound.
  • Pull-Type Relief Valve Operation - More precise relief of excess boost and is compatible for a wider range of boost pressure
  • Primary Valve (Small) - Lift off the throttle, and the primary valve instantly opens, quickly discharging initial excess boost pressure.
  • Secondary Valve (Large) - Combined with the Primary Valve to provide optimal blow-off operation from low to high boost ranges
  • Dual Valve Structure, Sequential System - At low boost ranges the Primary Valve opens, and at high boost ranges the Secondary Valve also opens, resulting in linear response and optimal blow-off operation at all boost levels.
About Torque Solutions HKS Flange Adapter
Torque Solution Billet Aluminum HKS Blow off Valve Adapters allow you to install dual HKS BOV's onto your Kia Stinger 3.3T without any welding or modifications. Machined groove on the bottom of the flanges utilizes your OEM o-ring gasket. We include new o-ring gaskets for the HKS BOV and stainless steel install hardware to ensure your kit will continue to look good for years.
  • CNC Machined Billet Aluminum Flange (2)
  • M6-1.0 x 14 Stainless Hex Bolts (8)
  • Direct Fitment
  • Limited Lifetime Warranty
NOTE: CANNOT SHIP TO CALIFORNIA
