M'Kehyah
I installed the Eibachs and need to adjust rear camber prior to bringing in to alignment shop.
Is it as easy as loosening the camber bolts and then... rotating with a box-end wrench and re-torquing?
From previous posts about alignement after the Eibach install - I need to simply "max" them out (positive camber) so no fine adjustment is needed...
Thanks!
Thanks!
