3.3TT Help me make the G6DP 3.3L V6 in Engine Simulator
XGC75
Need some help figuring out very specific details of the HKG G6DP engine. At the end is a list of the parameters I need.
In case you haven't seen it, Engine Simulator is a neat little labor of love made by a guy that just wanted to see what various engine configurations would sound like. It's a lot of fun to tool around in - pretty remarkable how good it sounds for what's packaged as such a "simple" simulation. The LFA V10 sounds like the LFA, and the Merlin (WW2 V12 airplane engine in a lot of fighters like the Spitfire) sounds like a Merlin. But it doesn't have the G6DP, so I'm building an engine configuration to simulate it.
G6DP Parameters:
Engine
Bank: 60deg
Firing Order: 1-2-3-4-5-6
Displacement: 3342cc
Stroke: 83.8mm
Bore: 92mm
Compression Ratio: 10.4:1
Chamber Volume: 59.25cc
Rod Length: ? (default V6: 5.142in)
Rod Mass: ? (default V6: 535g)
Compression Height: ? (default V6: 1in)
Crank Mass: ? (default V6: 50lb)
Flywheel Mass: ? (default V6: 30lb)
Flywheel Radius: ? (default V6: 6in)
Timing Curve: ? (this one is tough - the app doesn't simulate either turbos nor variable phase intake/exhaust ports so just assume full throttle timing for best results)
Intake Plenum Volume: ? (default V6: 1.325L)
Intake Plenum Cross Section Area: ? (default V6: 20 cm2)
Intake Runner Length: ? (default V6: 4in)
Exhaust System Length: ? (default V6: 100in on bank 1, 172in on bank 2)
Piston weight (including pin): ? (default V6: 566g)
... more to come as I edit
