MerlintheMad
10000 Posts Club!
When carrying tall loads in the hatch, the cover needs to be removed from its hinges so that it can "float" above the tall objects (e.g. ice chests).
I discovered (this is not going under "interesting discoveries" it'll get buried) that pushing and pulling on the hatch cover, to snap and unsnap the hatch cover hinges, will break the hinge from the cover. The only thing holding my left hinge in place right now is the felt covering. It looks like I'm going to have to cut around the base of the hinge and apply Gorilla Glue or similar. From now on, I will only snap or remove the hinge by applying direct pressure to the hinge, not the cover. No glue join is going to hold up indefinitely if sideways force is applied to it.
