Driver position memory system reset
If the Driver position memory system reset fails to work, initialize the system as follows.
How to initialize:
1. Stop the car and open the driver’s door with the Engine start/stop button in ON and the automatic shift lever in P (parking) position.
2. Pull the driver’s
seat forward as far as possible and have the
seat back upright as much as possible using driver’s
seat forward adjustment and seatback angle (recline) movement switches.
3. Push SET button and
seat forward movement switch button for 2 seconds simultaneously.
Initialization in the process :
1. Initialization begins as the alarm sounds.
2. The
seat and seatback will auto-matically move backwards. The alarm sound will continue while the system is in operation.
3. Initialization will be all set after the
seat and seatback move to the center with alarm sound being raised. If, however, any of the following occur, the initialization process will come to a stop and the alarm sound will stop as well.
- When pushing driving position memory system button
- When pushing driver’s
seat height adjustment switch
- When changing the shift lever from P position to other positions
- When the driving speed exceeds 3 km/h (2 mph
- When the driver’s door is closed
