3.3TT Front tyre size
Marth06
Hi
The front tyre size OEM is 225/40/19.
Any issue in fitting 235/35/19?? I don’t think there is but thought I’d check…..
I would also like to fit 265’s to the rears but that is not advisable on 8.5inch wide rims(?)
Hi
You can fit up to 255s in front and 285s in the rear on stock tires without issue. I've had 255s up front and 275s in the rear with 20mm spacers with no issue.
Thanks, I'm thinking of running
Front 235/40/19
Rear 265/35/19
on the factory rims. There about the same diameter......same difference of 3mm as the factory setup
don't see any issues with that setup?
Front 235/40/19
Rear 265/35/19
thats the exact size i've been running for the past 2.5 years 30k miles with no issues on factory wheels.
same here. no issues whatsoever on 235/40/19 and 265/35/19.
Great thanks for the feedback. That’s the setup I’ll be going with.
