Error codes
Theo.skev
Hi,
can anyone help me I have P259e and POOAF error codes on my my Kia stinger 3.3l, I am not able to clear them can anyone point me in the right direction to get this resolved.
Does anyone know what’s a good obdii scanner to buy?
Hi,
They won't clear? Or you don't possess the tools to clear them?
It doesn’t seem to fix the problem, I have lost boost and nothing works I cannot get the boost levels back
Hi I have the following error codes on my Kia stinger does anyone know how to fix and where to look? P2562 and p259e
These are related to turbo control sensors. Do you have any mods on the car?
Yes I do have got mods on the car, air intakes, catback exhaust, do you think the sensor needs replacing?
I was thinking if you had a jb4 that something with those connections could be messed up.
What year is your stinger? 2022’s have had some overboost issues, even stock that were exacerbated by even the mildest of mods. But your codes seem different.
I had the jb4 on when I got the code and I have lost boost nothing works to fix it.
Could any of the wiring been damaged?
Last resort take it to the dealer.
Why didn’t you clear the code with your JB4, set it to map 0 and go from there?
I have done that multiple times it did not fix the issue. That’s why I removed the JB4 to see if the JB4 was causing the issue.
How did it take the codes to come back when you cleared them?
Any update on how you fixed this?
Currently pulling the P2562 Code
