BAO
- Nov 30, 2019
Took a jump into modding, and having issues. I have spent a fair amount of time on these forums but haven't seen this issue pop up.
My engine shakes, sometimes, on half throttle and full throttle. It doesn't shake every pull, but it does shake about half the time when I give it a little throttle around 30mph in 3rd or 4th gear, and it shakes a little less than half the time when I go WOT. Sometimes the engine shake is a mild annoying vibration, and sometimes it feels like a major, bad vibration.
I did recently have a reputable local installer put in JA airscoops, a jb4, denso plugs, an addw1 dual inlet OCC, injen intakes, ark GTF springs, and a rear eibach swaybar. I also went from the stock 18" wheels to some stance sf07 20".
I have had the installer check the jb4 connections, and Terry himself has said my logs look fine. The installer gapped the densos properly. I had a professional alignment shop verify and set everything after the springs were put on.
A few other random notes for everyone mod-savvy, not sure if these will be helpful or not.
- The AddW1 dual catch can came with two blown check valves. I had them replaced. The shake was there when the check valves were blown, when the installer plugged the intake (ie disconnected the occ), and after the replacement check valves were installed.
- I ordered a set of sway bars, but the front Eibach sway was out of spec from the factory. The bushings were not to size, which resulted in lateral movement on the front sway. Eibach confirmed this was an issue and is sending a new one next month. Installer put the stock swaybar back on the front, and the alignment shop didn't notice anything with the stock sway after reinstall.
-The JB4 or the OCC (or something else) caused a few CEL the first few weeks these mods were on. It threw a p0068 (which we thought was JB4 caused) and a p0507 (which we thought was the OCC check valves, per this thread Vacuum Leak? Check your catch can). I have cleared all those codes, disconnected the JB4 for a week or so, reinstalled it myself with install pictures sent to Terry Burger who verified the connections looked OK, and everything has been running with no CELs since then.
- My own novice guess was an engine mount, but the installer checked and said that looks Ok, based off of some engine revs at park in the shop (no vibration during standing revs).
-Based off of all that above, installers newest guess is that the injen intakes are transferring the engine vibration to the chassis, given their setup.
Any ideas? Has anyone ever had an engine/chassis shake before with densos, jb4, and injens? Any way for me to run some tests at home or take to a local shop before I head into the dealer?
