So i just got the eibach springs installed along with the whitelink swaybars and endlinks. I have sort of a clunking noise which i have been told is creaking. They said it should go away after the springs "settle", is this a normal occurrence?
I had zero noise with the rear Eibach sway bar for over a year and a half. Since getting the front bar in, it definitely "creaks" when going over the entrance to our driveway, and negotiating any speed bumps, etc. I suspect one of two causes: either the fatter bar is rubbing on the deflectors (that protect the steering boots), or the mounts were not greased properly. It is a very faint creaking and only when the front suspension is flexing in those extreme conditions; you can't hear anything when out on the road; so, I haven't worried about taking it in. When I get my oil change done in a few hundred miles, I'll mention it to them and see if they need to lube the mounts.
I'm assuming that you mean, "Turn the wheels all the way one direction," out of the way. And then spray this silicone stuff directly on the boot protectors (where the bar rubs) and on the bushings the bar runs through?Merlin, just use some dry silicon spray, turn the wheels all the way one direction and then the other, and use the spray tube to silence the squeaks. It worked wonders on mine.
out from what?Yeah, ok. I am out.
Ah, wondered where you went. I just wanted any pointers about how to "point" the spray the most directly. I figured it out on my own. Bought some "Blaster Industrial Strength Silicone Lubricant" at O'Reilly's. Sprayed it on both the areas where the bar passes in front of the steering boot deflectors, and the barely exposed outer ends of the sway bar bushings. Then I drove away from the parking lot and heard SQUEAKING in place of the previous soft creaking!? I was mildly horrified, but decided to not panic because this was probably going to change and not for the worst. Sure enough, by the time I got home (less than five minutes later), the entry into my driveway was quieter than the initial SQUEAKING; now it was just a small squeak (imagine something a bit more piercing than a creak). Later in the day I gave the four spots another squirt of the "Blaster" and let it sit overnight. Now there is almost silent movement from the bar. I didn't notice any noise at all today. If there is any, it is so soft that it doesn't get my attention.Yeah, ok. I am out.
