boosted1g
Sustaining Member
Here is a video I made of a much simpler way to remove those stuck on rear rotors vs hitting it with a hammer or prying it off.
All you need is a bolt and nut:
Put the bolt into one of the two caliper bolt holes, and thread the nut between the caliper mount and the rotor.
Tighten the bolt until the rotor pops, loosen the bolt a bit, rotate rotor maybe 1/4 turn, repeat and the rotor pops right off.
