Coolant leaks!!!
Siddharth
Ontario
Hey folks, I noticed coolant leaks on the engine block. Not sure what might be causing these as the coolant in the reservoir is also below the 'L' line. Attached are the pictures. Could someone tell me what's causing this?
You need water pump replaced. Easy job.
I vote water pump too, similar case here:
Pump gasket looks like. Thankfully its fairly easy to get at, get it done soon though and add some coolant in the meantime.
