DevLF
I've read about the fuse pulling scenerio to convert an AWD -> RWD but i was wondering if anyone has wired up a toggle switch into the cabin to toggle the fuse being open/closed? I was thinking a fuse socket connector with some wiring that includes an inline fuse with the same amperage as the stock one should do the trick.
But also, has anyone had any experience removing the fuse while the car is running or driving and has that caused any problems?
Another thing I was curious about is since the GTS has the factory option of going into "drift mode" has there been anything about potentially a plug 'n play solution using OEM GTS parts?
