So I have been dealing with an intermittent no start and wondering if anyone else has run into this? First time I was out of town for the weekend and it was about -15C car sat out for 2 days. Car would not start. It turned over but slow. Seemed normal given the cold. Hotel offered car to boost. Popped the hood and hooked up to boosting post. using the dash button the car would not even try to turn over but the dash would turn on a light up like it started. I have an Idata remote start. Tried the remote and hood open fault. Closed the hood and opened the trunk. Unpacked and pulled the spare tire. Hooked up to the battery and still not turning over with the dash button. Remote start would turn over the engine but no start. Left it to charge for a bit and tried again. 30 min. of boosting and it started.
Drove home and had battery tested. Battery tested good. Next time was a work, 8 hrs -20C, Tried remote and it didn't start just turned over. Tried dash button and it didn't turn over just the dash on like it started. Hooked up a battery charger and tried it. No start. Thought maybe the Battery maybe getting weak and when cold the draw was to much to turn the ecm on and crank. Went and bought a new battery and put it in. New warm battery and no start. Next day I plugged in the block heater and put a charger on the battery. That afternoon it warmed up to about -5C and it started.
Booked it in at the dealer and left it there overnight outside. Of course it wasn't a cold night and it started for them. Only code was low voltage code. They reset the remote start module and tested the battery again. Picked up the car and they said there is nothing wrong.
A week later we have a cold snap and -20C and colder all week. Car plugged in and it started on Monday, Didn't start Tuesday. Boosted with battery charger and after sometime it started. Unplugged the remote start module and on Wednesday it didn't start. Hooked charger up and after some time it started. Thursday Would not start. It was plugged in and charger on it. I work at a shop so I got help to push it inside. 2 Hrs later it started no problem in the shop.
I park in a heated garage at home and had no issues starting anytime it's warmer than -10C. It never shuts down after it runs for a few seconds. A Couple times when boosting in the cold it started and shut right off. I would let it charge for a bit then it would start and shut off. Then it would start and be fine until the next time left in the cold.
One other odd thing is if I use the remote starter and turn it over for the two attempts then try the start button it will crank for a split second the first time only. Like remote button crank, crank ,crank stop. Crank, crank, crank. Remote start shows failed start. Get in and hit the button and it will kick the starter for a split second and turn the dash on. After that it doesn't matter how many times I try the start button it won't kick the starter. Then try the remote and it kicks the starter on the first try only again. Weird!!
I didn't find much online for Stinger's not starting. Other than the normal starter or battery or connection issues. I did find some other kia models with starting problem but nothing like this.
I did try switching the start relay with another one. Also tried turning the car on with the start button and jumping the large pins on the start relay to crank it over and it will crank but not start. I even tried spraying some ether to see if it would run on it. Nothing. So it's spark not fuel. I don't think it would be wiring being temp. sensitive and not having issues driving. I tried unplugging the ecm and checking the pins which look good.
Any Ideas?
Any Ideas?
