Check engine light after JB4 and BMS intake install
Hey guys,
I installed my BMS intakes and my JB4 (Although I did not have the bluetooth cable so it should not have affected anything yet) and got codes p0238 (OBD-II generic code triggered when the Engine Control Module (ECM) detects the intake boost pressure sensor A input circuit out of specifications, indicating an open circuit or high voltage condition in the circuit.) and p0302 (Cylinder 2 misfire). I have checked all the hoses and they seem to be secure. The data cable connections for the JB4 also seem to be fine. Anyone have any ideas?
ECU noticed the sensor was disconencted. Clear codes ign on, engine off, and see what comes back up.
Terry you are the man. That solver it immediately! I will still upgrade the plugs to the specs you gave us but it's good for now!
So i thought we were good. The p0238 code never came back but the misfire code did and with a very definite misfire. Car got real vibraty until I was restarted.
