Striker's Stinger
- May 1, 2022
I just got my JB4 w/ HKS spark plugs gapped at 0.022, and Injen Intakes installed. I run Shell 93 octane V-Power Nitro+ only and MAP2 daily. Damn this car is fast. I just got bored and ended up buying a 6 pack of 32 oz Boostane Professional. I downloaded the Boostane app, and saw on older threads Map 3 can be safely ran on 96 octane, which according to the Boostane app, is 2.88oz per 16 gallon fill up. To be on the safe side I would run Map 3 on 97 which is 4.16oz. That being said, that’s about 46 fillups, so I’m loaded with boosters or can run higher octane. Where I’m at though, there is no E85 option. I want to try Map 5 for some time, is there a safe octane level to run Map 5 with Shell 93 and a shit ton of Boostane? I can get to 100 octane with 14.72oz which is less than half of one can, or 102 octane with less than a full can.
Also, I am a daily driver. Mostly use my car to drive to work and back and have decent open road stretches to have a little fun. I run Map 2 daily on Shell 93 and have had zero issues so far. Should I always run Boostane if I want Map3 as my daily? Can I put Boostane in every fillup even if I want to still run MAP2 daily? I read in earlier threads MMT is bad and can mess up the spark plugs at a shorter than expected time? Should I only use Boostane when I’m going to the strip?
