Brake pad replacement
Sargie
Hi all. Happy new year. I'm new to forum. And was wondering if anyone has an opinion on alternative to Brembo brake pad replacement. Prices quoted seems high ??
There are some options for brake pads. I believe the rear pads are rare and the ones that were available are on back order until sometime early this year. Are you trying to replace because you are getting brake shuddering or do you want increased performance?
Stoptech Performance - Front & Rear Street Ceramic Brake Pads
Howdy. Brake pads/rotors discussions are among the most lengthy and frequent on the forum. Try a search. The consensus in the US is that the OE pads are good on dust (little to none) and poor on sustained performance driving demands (brake fade and afterward shuddering). Even normal driving produces a number of disaffected drivers with shuddering brakes (aka "warped rotors"; but actually pad deposits). As already stated, rear replacement (aftermarket) options are limited; to, currently one offering (forget the name brand); front pads are quite numerous and span the spectrum of dust/higher performance, to OE equivalent (clean running, but risking pad deposits).
