Secondchance
- May 27, 2019
Received my unit this week and installed it on the car on Wednesday.
Fitment 9/10
- You will likely need to trim a small part of the inner plastic shroud around the radiator/intercooler.
- The hole for the third bolt that goes through the middle of the front camera/sensor on the GTS/GT LTD did not line up.
- If you have a newer Canadian GT LTD and the dealership installed the quick connect in the front grill for the block heater, you will need to remove the entire cable all the way back to the block heater itself.
Quality 9/10
- Comes packaged extremely well, and from what I could see, all the welds were clean. I had zero damaged fins, but the thing is heavy!
- I was sort of annoyed that they didn't include one more clamp to replace the passenger side rivet clamp on the factory hose you otherwise need to reuse..
Overall 9/10
- I have my JB4 out of the vehicle right now (winter/haven't reinstalled yet) but even on the stock tune you can feel a difference. In particular, the throttle response is much better than it is with the stock intercooler. Would recommend.
Fitment 9/10
Quality 9/10
Overall 9/10
