Since I got a ceramic coating on my Stinger a while back, I've been washing it using water only with no problems. Recently, I decided to use car soap from a company called Sonax. The soap is called Sonax Gloss Shampoo, and they say that it's pH neutral. I washed my car using it twice now, and I can see the water beading when I first pressure washed the car before applying the soap.
After I applied the soap and rinsed it off, there was almost no water beading even after thoroughly washing off the soap. Although the second time I washed the car, the water beading was back. The same happened after I used the soap for the second time, water beading was gone (except for the windows, for some odd reason). So, I'm unsure if doing this will eventually completely remove the water beading? Thanks.
