Typeface
Pretty disappointed with the QC on these to be honest, especially seeing the cost of them.
Firstly the air filters don’t fit through the holes with that useless piece of auto trim, one didn't fit through the hole with the trim removed (well fell off), i had to use a sharp exacto knife to make the holes larger, something i never should of had to do. Once i made the holes large enough for the filters to actually go through the holes the trim didn’t stay on at all due to the thickness of the plastic now, they didn't stay on from the outset, surely test the fit and glue the trim on then test the fit again, simple quality control, needless to say no trim and a gap around my filters. I will have to look for some better trim with a deeper slit so that it will actually fit the holes and then glue it.
The drivers side tube to me is to long as it pushes the hose clap into the hole the filter goes through and the filter is jammed against a part on the car.
“You may need to loosen the clamp at blow off valve to prevent tube from kinking.”
No I had to cut that hose as it was bent and kinked to almost closed once connected, had to take 20mm off. If i have to go back to stock at some stage that hose i had to cut wont be long enough.
These things definitely need work to get anywhere near “Fits Kia Stinger” claim, yeah it fits once i had done everything i just said above. Did i just get a bad batch? Anyone else have these issues?
For the price and what i had to do and the end result i couldn't promote these to anyone.
