DustinCheeks
 - Sep 24, 2021
So i am thinking of adding the BMS Dual Cone Intake and BMS Zero Maintenance Oil Catch Can offered on the "KDM Warehouse" to my 2021 GT1 and i have a couple questions for anyone who can help!
To my understanding these items are pretty much plug and play and do not require any additional add-ons to ensure proper use and lifetime, correct? Or is there something(s) that I'm missing that is required to add (in addition) to these two items?
Also, any advice in regard to add-ons that will help increase the performance of these items would be awesome.
Lastly, the website states... "Note the Stinger has two separate PCV paths, vacuum side and boost side. The BMS Zero Maintenance oil catch can is for the vacuum side which we’ve found contributes ~95% of the manifold PCV oil contamination. With the Stinger we have not found any significant benefit to adding a separator to the boost side (driver side) system and suggest leaving it factory." Has anyone had any experience with this specific OCC or other 0 maintenance OCC's. Would you recommend going this route or getting the dual OCC's for both sides?
Thank you in advance for any help/advice offered!
