My new Stinger has it. First time I have ever had the adaptive cruise. So it was a new experience for me. A couple of things I noticed. I was driving my new stinger home from a dealership on the other side of the state so I had about 250 miles to learn about it.
Here are my observations. (Remember I've never had this feature in a car before)
- It's pretty cool and seems to work well enough.
- I wish I could manually adjust the distances (like 80ft at 75mph). You have 4 adjustments that set the distance dependent on your speed. The 4 bar setting is something like 180ft at 60mph and the single bar is like 80ft at 60mph.. Holy crap that is way too far (4bar). And it is just an invitation for cars to hop into your zone which causes all sorts of mayhem with the system.
- The system seems extremely aggressive with its slow down adjustment. I had it set at the 4 bar setting, doing 70mph, which has to be around 200ft, and a car jumped across my lane doing 70mph. The stinger slowed down to like 60 or 55mph very quickly, which cause problems with my wife that was following behind me. The car that crossed my lane was WAY up there maybe over 150ft.
- The shortest distance setting, 1 bar (80ft at 60mph) seems to far away also, for congested highway conditions. If you are in heavy traffic, this system does not work well. It leaves way too much space in front of you, and slows way too quickly. It pisses people off that are following you.
- Driving through the mountain pass I was in the left lane doing about 65mph, and I was coming up on a Semi in the right lane doing about 60mph. The highway turned to the left a bit, and the system seemed to pick up the semi in the other lane and slowed down to his speed.
- The system seems very suited for open highway and works well. Not sure if I would use it on busy highways like I5 or the 405, It just leave too much room.
Thanks
