Juanma
- Mar 10, 2026
Hi everyone, I joined this forum to get help, a few days ago I drove my car around town and then I had to make a stop somewhere but left the car parked and engine running my wife was inside and it was a little bit cold outside, I had it parked for about 30 minutes, when I came back I’ve noticed my temperature gauge all the way to red HOT and my warning codes came on on the dash, long story short, I found out the fan is not turning when it should, tested fuses, relay and continuity everything is working normal, I have 4 wires coming the the fan 2 hot wires 1 ground and 1 coming from temperature sensor, I tried hot wire the fan but couldn’t make it turn so I thought maybe the fan was bad, I ordered a used one but supposedly working condition but I can’t make it turn either by hot wiring it also, ohh I also replaced the temp sensor for a new one didn’t make a difference, so I’m here still looking for an answer what could be wrong with it , maybe someone have had the same problem… please Help!!!!
