Thwack
- Feb 13, 2018
So this is probably the 3rd version of these out there right now, I had some extra time at home, HyperJetta had taken a break from making them, so I figured I'd come up with my own version.
I wanted to keep the Radiator shroud and cut as small a hole as possible into it, so I made the snorkel 2 pieces to keep the intake mouth wide, and the back end fitting onto the stock tube, the middle ends where they meet inside the shroud are narrower. I wanted a shape that would flow with the grille better and be a more interesting shape than rectangular, so I made more of a polygon shape, reminiscent of the hellcat charger intakes which I really like. I also printed in 2 colors, with the mouth as a silky/ shiny red filament that matches the red color pretty well Below is the outcome, hope you all like it.:
The back pieces alone would work for a mote stealth look, you just get a narrower mouth.
Couldn't get a good photo where they stand out, but in person you can see them easily.
