100,000 Mile Tune Up
Anyone have a thorough tune up at 100,000 miles? I'm talking walnut blast, oil change, new spark plugs, transmission fluid change. I'm also considering replacing the brakes (still on original brakes) and changing the battery (still on original battery).
Don't forget the brake fluid. If they have not been flushed with new DOT4 since new, it's way overdue.
As for the battery... sitting in the nice cool clean trunk floor, they typically last a long time. No need to replace, unless there are signs that it needs it. Best way to be sure is to get a battery load tester. Like this: 100 Amp, 6/12V Battery Load Tester
good to know the battery lasts that long, if anyone needs an OEM battery in Tampa area LMK :)
