Hi,
I am in AZ as well. Is there a chance I could contact you and have your expertise on this car. Thanks!! Mike
Chris is correct. Immediate buyout mitigates almost all of the rent charge (interest) which is applied to both the Adjusted Cap Cost and Residule Value.
Without seeing the contract it would be difficult for me to be exact. But based on the numbers above...
Adjusted Cap Cost is $40141 - $6700 = $33441
Rent charge per month is ($33441 + $21200) * 0.00195 = $106.54
You must have rolled some other stuff into amortized amounts because I calc the base payment at $446.56 without tax and $473.91 with tax. I'll use your monthly of $529 below however.
Adjusted lease balance per section 22D would be $33441 minus any accrued/paid depreciation and amortization...so $423 ($529-$106). Now you are at $33018. Remember that rent charges are earned in advance. So, assuming you do this right away, the portion of unearned rent for the month would be retuned/factored in. Assuming same day buyout, the depreciation and amortized amounts paid is only the first month so it would still be the $33018. This would be the balance subject to rent so $33018 * 0.00195 = $64. The remainder of the $106 rent charge comes from interest on the residual which, as Chris mentioned, is no longer required.
There may be some daily interest factored in as the contract mentions the constant yield method but it would be minimal at best. This is standard for a typical 10 day buyout amount on any loan.
That all said, I would approx your same day buyout (adjusted lease balance per sec 22D) to be approx $33K plus tax, so approx $35K'ish total.
I'd also like to add that I'd take 6.25% along with those license fees anyway of the year. Much higher for both here in AZ.
