OEM Remote Start Installation How-To
Grishbok
If you're in the US and feeling shafted by the lack of remote start like me, you can get an OEM remote start from kia. Fear not, I'll walk you through the installation process.
The instructions that come with it are great, but removing trim panels can be a bit daunting to the every-man and nobody wants to break a panel on a new car. So I'm going to tell you how to do this without doing that so you can save some money on installation by doing it yourself.
What you'll need:
1. Purchase the kit. OEM Remote Start Genuine KIA acessory. Heres one from KiaPartsWorld for $400
2. Get a set of trim removal tools. Something like these: Trim Removal Tools
3. Something to cut the tails off the zip-ties
4. flashlight 'cus hey... it's dark down there.
1. When the kit arrives, check the box and make sure all the parts are there. Nothings more annoying than starting something to find out your missing a piece and have to wait. There's 3 main pieces here, the wiring harness, the control module, and the Receiver Module. (2 key fobs and zip ties).
Note: Go ahead and attach the wiring harness to the new control module, make sure you plug it into the correct side. The instructions will show you the image of the module, pay attention to where the sticker is on the module in that image so you plug it into the correct side.
2. As per the instructions, you'll want to disconnect the negative terminal from the battery. Did I do this? no, and that was dumb. I REALLY should've disconnected it. I was lucky and nothing happened but man, i really should've disconnected it.
3. On the passenger side, open the door and gently pry the weather stripping off the rail and let it hang out of the way.
4. The instructions will tell you to remove the Door Threshold Panel. This is the trim piece directly next to the seat, in-between the aluminum door sill scuff plate and the seat. This needs to be removed first so you can gain access to remove the passenger kick panel as the two pieces overlap slightly.
Once you've moved the weather stripping out of the way, you'll see it is held in place by 3 clips that can be pushed inward and up to release, and 2 hooks (one on either side). Release those and pull upward. Once released, set the panel aside.
5. Next, remove the Lower HVAC panel. This is the panel right below your glove-box. This ones easy, just reach under it and look/feel for the 2 pull tabs near the top, pull them upward to release the panel. If you have a light installed there, you will need to disconnect it once you've removed the panel. NOTE: there is NOT a lot of slack in the wires, so be careful not to pull the panel until you've disconnected the light.
6. Remove the passenger kick panel. This is the panel between the door and the lower HVAC panel you just removed. This is the tricky one. It's held in by a tab and a push-pin as noted in the image. The pushpin is completely hidden behind the panel so to get to that we'll undo the metal tab first. The metal tab you will see easily on the top right of the panel next to the weatherstripping. Dislodge the tab to give yourself a tiny bit more give in the panel, and shine a flashlight in the gap if you have to. You're looking for a tiny little bit of white which is the push pin, circled in the attached image. You'll need your forked trim removal tool to slide behind the panel, capture and dislodge the white pushpin. Take your time here, the last thing you want to do is break anything, it did not require a lot of pressure to pop it out, the trim tool just has to be in the right place.
7. Now you have access to the electrics. The receiver mounts in the back at the firewall, refer to the attached image for visual placement. Zip tie it to the factory harness as high up in there as you can get it.
8. The control module goes right up behind the factory IBU, which you can easily identify as the other box with red/blue/green connectors. Your going to zip tie the new control module directly behind the factory IBU, it will fit snug. The wires with the yellow tape on the connectors from the new control module, will make a U-shape, coming down underneath the two modules. You'll zip tie the new control module also as high up as you can. Mounting this too low will interfere with the trim panels re-installation.
9. Unplug the red/blue/green from the factory IBU and plug them into open ports on the new control module, then plug the red/blue/green from the other side of the new control module, into the newly vacant slots on the factory IBU.
10. Plug the two remaining connectors into the receiver.
11. Reconnect the battery, and test it out with the included remote. Follow the instructions to check the functionality but you should be good to go. You will need to hit the keyfob button once to lock the doors, then within 3 seconds, press the button again to activate the remote start.
12. Put all the panels back in reverse order.
13. Push the weather stripping back into place.
14. Enjoy the new remote-start function!
Note: you can start it by pressing Lock, then either trunk or horn button within 3 seconds to activate remote start without using the additional keyfob.
Enjoy!
It is pretty easy, the only part where I see people going wrong with it is in the kick-panel removal. That push pin is really hidden and protected quite well, but hopefully this guide and seeing the simplicity of it in the pictures will help people save a bit of money and do it themselves!
I would recommend that after step 6 there be an additional step to replace the threshold panel while working on the harnesses and control module if you plan on laying across that with your arms and head in the footwell. I laid towels over the area exposed by the threshold panel and still managed to fracture a rib. I don't expect that to be common (I have performed work on cars in a similar manner before without any real issue) but I really wish I had thought to replace the threshold panel why working now.
Is there a way to add in the UVO smartphone capabilities like the Candian version of the Stinger has? Pretty disappointed that the US version doesn't have this. Also why can't I put my windows up and down with my key fob? My friend just got a Honda Civic and his key fob can do this on a car that costs half as much. Most new cars have this feature, the Stinger at this price point should have something like this!
Well, to the best of my knowledge, in order to use your smartphone as the remote start, the car requires a key component that is missing from the US models. A SIM card. The SIM card is what connects the car to a cellular providers network and allows your cell phone to to send the signal over the cellular network, to your car. Now, you can get an aftermarket SIM card and pay a monthly fee to connect it to the cell network. Some third party remote start/tracking systems have this functionality included with a monthly fee but the OEM remote start does not.
This SIM card and any SIM related functionality is missing from the US version (for now) and I suspect it is because Kia would have had to make a very large-dollar deal with one of the cell phone providers to give service and infrastructure to support the US version of the car which would ultimately jack up the price point even more, and economically, adding cost to a new model with no idea how it will be received in the market is a big big big risk, too much risk for this cars launch.
That actually makes a lot of sense. I guess when it starts getting colder I'll get the standard remote start. Thanks for explaining this!
So the install is pretty easy and would have taken me 30 minutes except I zip tied around the HVAC panel light cable making the cable too short and should have zip tied above it, so I had to undo everything snip the zip tie carefully off and rezip tie. It cost me another 20 minutes.
And to start my car, I hit the lock button and then hit it again on my original key fobs that came with the car.
Thanks to the OP for the pictures helped a lot. Overall fairly easy as installs go. 90 degree humid Georgia weather had me sweating golf balls though.
Only had a couple hiccups. Didn't realize I needed to really get in that far under the dash so didn't have the seat all the way back before I disconnected the battery, and was too lazy to reconnect, move the seat and re-disconnect.
Also after I had all the panels covered up and started the car I got a tire sensor error and the car wouldn't go into gear. Took the panel off and found one connector wasn't seated all the way, so an easy troubleshoot.
Works perfect. My original key fobs works without any programming.
By the way, bought mine off ebay new for $340 and ebay was running one of their promotions again so actually cost less than $300. Something tells me ebay must be hurting, reminds me of Circuit City - they had crazy promotions before they went under.
Just finished installing mine tonight. Took me about 1.5 hours to do everything being careful not to break anything. Many thanks to the OP for providing instructions. A few things I wanted to add and point out with my experience. Hopefully this will help others.
1. First of all, move your passenger seat all the way back.
2. Take the extra effort and disconnect the battery. The last thing you want to do is short something out and make a bigger mess than you have to. (see pic 1).
3. The footwell cover has 3 holes that has the release tab. Feel inside the hole and you should be able to feel the tab. Now either pull it towards the direction of the seat or push it towards the direction of the engine (sorry can't remember) as you work your way from one side to the other pulling the panel down. It shouldn't take too much effort (see pic 2)
4. Once the cover drops, you will see the pin connector for the foot well light. Depress the tab and pull from the connector socket. Now you can set aside the panel. (see pic 3)
5. Once the weather stripping has been removed, use a wide panel remover with the hook end. Get under the gap of the metal tab and use the side metal rails as a leverage to pry the pin up. Work your way from one side to another and it should come off. Mine did not come off all the way, but I only need to get to the kick panel so I left mine partially removed. (see pic 4 and 5)
6. To get to the kick panel, pry to top portion with the metal tab as the OP recommended using a smaller panel tool remover. Trying to get to the push pin is a PIA, but what I found out is if you can get your hands under the kick panel, you can pull it off from underneath and it just pops off without needing any tool. (see pic 6)
7. Once that is off, your half way through your battle. Go pat yourself on the back and have a cold drink. If you have super powers to shrink yourself, now is the time to do it because the next step requires some flexibility.
8. Now twist your self so that you are looking up from underneath. You should be able to see the IBU module. You will find a big space beside it. That's there the Interface module will go in. If you think that is big enough gap for easy install.....you're in for a surprise. (see pic 7 and 8)
9. Just off to the side of the kick panel, the is a space there, that is where the control module will go. Instructions says to zip tie it on both ends, but I was only able to zip tie one side. It gets quite difficult trying to run the zip tie in there once the module is in place so if you are able to zip tie both ends, good for you. I can tell you thought that it's not gonna go anywhere. It gets quite tight in there pretty quick. (see pic 9)
10. I test fitted the Interface module which will be beside the IBU module. (see pic 10)
11. Connect your wires as instructed on the instruction manual. Make sure you hear it click, if not, put some ass into it and push harder. Again, the instruction says to zip tie it on both end, but I was able to only zip tie one side. When all the wires have been connected, there is very little room to work in there to route the zip ties. I can tell you as well, that module is not going anywhere. (see pic 11)
12. Putting the kick panel back can be a challenger too. You're gonna need some patience and keep pushing those wires as high as you can or off to the side. to get the kick panel back in there. Align where the push pin go along with the metal tab, and push back in. you might need to give it a whack or two for the side push pin. Did I say the wires gets in the way and you have to keep pushing that dang thing out of the way? If you didn't, push it up or to the side, and try again. Don't force the kick panel, do it as gentle as you can.
13. Oh before you put everything back, test it out and make sure the remote start works. The last thing you want to do is put everything back together, then realize it doesn't work. That would suck!
14. Don't forget to affix the warning sticker as the instruction says. This helps the technician who will be working on your car at the dealership know that there is a remote start on the car. Saves you for being blamed if they mess something up because they didn't know you have a remote start. (see pic 12)
15. If everything works, put everything back together and enjoy your remote start.
To Grishbok and SilverNitr8... THANK YOU for posting your instructions and photos. It’s because of your sharing of the procedures that I was able to successfully install remote start on my ‘18 GT2. The factory instructions were not all that helpful and your instructions filled in all the gaps in the details. I used a lot of explicatives and it did take me about 4 hours over the course of two days, but it’s working and everything is put back together correctly.
One question for others who’ve completed the self-install.. did you guys have any problems with the rear hatch after reconnecting the battery? I couldn’t get it to close by any electronic means so I ended up, after an hour of trying to troubleshoot with the owners manual and online searches, closing it manually. That seemed to reset the system and it seems to be working ok now. I ask because I didn’t see mention of this anywhere in any posts and it happened to me both times after disconnecting/reconnecting the battery.
You're welcome. I'm glad you were able to install it yourself. I personally did not have any issues with the hatch after installation.
Same here, installed it today and it also took just over 4 hours, a few beers and a bunch of bruises on my arms. A HUGE thank you as well to @SilverNitr8 & @Grishbok for the how-to's. They were perfect!
wow it took u guys quite awhile to do. it honestly took me 45 min, I'm a smaller guy so my hands fit right up in there!
I did this yesterday, probably took an hour and a half. I got everything wired up in probably 30 minutes, but I couldn't get the kick panel back on. I took it all apart, redid my zip ties, and gently but firmly moved everything as tight as I could to the top and side of the kick panel space. Everything went together pretty well after that.
We were not in any rush, and took our time (ok ok, we were drinking beers). Biggest problem we had was the getting the damn kick panel off, and zip tying the module up under the dash.
