Brake Vent Fix
Status
Not open for further replies.
Does any one what a copy of the templates? They are very ad hock but I can scan them onto a A4 doc.
Yes pls , would like to see a shot of the actual screen in a tight shot as well , great solution mate ~!
One thing to note, when you fit the mesh you have to lift the lining up slightly and slide in diagonally then shimmy it around til it fits in place. I used a small screwdriver to lift the edge up and over the mesh but be careful you don’t tear it. There is not much room to manoeuvre so take your time. Better if you can get wheel off. From start to finish took me 90 mins.
thanks buddy !
I think these mudguards plus the mesh in the vents should minimixe the rock chip issue
Ok after ALOT of stuffing about I got the screens in. I went down to my local security screen door place and they gave me some heavy duty stainless steel mesh which was painted black. I cut a template using cardboard from a cereal box and trimmed so it was slightly bigger than the hole as they is a recess in the brake vent opening that you have to fit to as the lining has to overlap it and hold it in and prevent water from getting in. At no time did I have to remove and lining or the wheels.
The hardest part was cutting the mesh. Any way all done! Looks great.
One other thing to note the vents are different sizes, don’t know why.
View attachment 7948 View attachment 7949
Your next job is manufacturing, making a DiY kit and getting it on the Bay. I say $49.95. (Discount coupon for forum members!) :geek:
Ya you are welcome for that brilliant idea I had. Just kidding looks great that’s what mine look like. It’s definitely worth few bucks and time to save on repainting doors. Watch how much crap collects in there between washes you will be happy you did it.
Kia I hope you are paying attention to these threads. Lots of stuff they can do to tweak car make it better.
Status
