I don't get anywhere near the kind of mileage. You must be the mileage whisperer.
That's steady highway cruising. I see numbers like 23mpg on your links, which is about what I'd average around town on 93. E30 means a 10% hit and puts me around 20mpg. Most of my trips are on 45-55mph roads, but with stops, and probably only ~15min average, meaning the couple minutes of warmup takes a bigger bite.
On ~25-30 mile drives around here, I'll break 25mpg even with E30, probably because the handful of stops are offset by the lower wind tax of cruising at 50-55mph, and coasting where I can.
I bet if I had the patience to do 65 I'd break 30 mpg.
That's what I saw on that leg to TX I mentioned. 30.5 MPG solidly, and I saw 31 MPG briefly. Iirc, the range kicked up to 355 when I gassed up that time.
Saw this today didn't know where else to post it?
What a car these things are eh ??
There are no seats IN the wreckage. How could anyone be alive, much less "not suffer major injuries"? We are seeing the laws of physics in abeyance for the usual mysterious reasons.
There was this one years ago.
And this one.
No survivors.
And this one.
No survivors.
I watched that grey one on youtube years ago...so sad right after they booked him for speeding 😞
I was driving 3 hours east to visit my parents and decided to turn off the motorway for a bit of fun on some country roads I know well. But this time, we stopped at a service station for some food, which meant I ended up taking a different exit. That forced me down a new route to get back toward the good roads.
Along the way, I drove through a grey forest and saw a crashed Mercedes in the trees surrounded by police tape. I took it as a bad omen and immediately slowed down for the corners.
A few bends later, I hit a series of potholes deeper than I’ve ever seen. It wasn’t just the depth, but the jagged edges of the caved-in tarmac facing the traffic. I managed to dodge a few on the narrow lane despite the oncoming cars, but eventually, I hit one I just couldn't avoid.
The "low pressure" warning chime went off immediately. I started to panic since this has never happened to me before, but luckily I saw a sign for a nearby village. I limped into a local BP garage to top up the air while I searched for tyre shops. There were three in the village, including two KwikFits (uh no). Both KwikFits turned me away because they were fully booked. The third shop also couldn't fit me in, but they offered to let me leave the car overnight.
I went into the boot and pulled out the tyre fix kit. It had a bottle of Tyre Weld rated for 19-inch wheels. I followed the instructions, filled the tyre with the foam, and immediately drove off to spread the compound around. I went back to the BP garage to top it up again; it was still leaking, but luckily MUCH slower.
I found a shop in Basingstoke (about 15 miles away) and rang around. Only one place actually had my tyre size in stock in case it couldn't be fixed, so I headed there. It was a nerve-racking drive, watching the PSI drop with every bump in the road. I kept it under 50mph like the bottle said (I felt bad holding up traffic!). I knew I could always pull over and use the compressor to pump it up again if I had to. I started at 38 PSI and made it there with 16 PSI left.
Now that I could relax, I inspected the tyre properly—it was a big crack in the sidewall with a bulge. Definitely unrepairable. It really hurt because I’d just put four new Michelin PS5s on, which had finally given me real confidence in the car.
They fitted a Chinese brand tyre as it was the only one they had, but it has decent rain grooves and I’ve done 100 miles on it so far with no major grip issues. The rims seem fine too (strong triangular shapes, I suppose!).
I was thinking, if the foam doesn't work, what do I do next time? I'm planning the NC500 trip around Scotland in 2 months and I really don't want to be stranded in the Highlands. Do I need to buy a spare tyre and rim? I imagine the rims are expensive.
I’m very thankful for the pressure readout; if I’d been in my old car, I would have been panicking a lot more and probably calling recovery because I wouldn't have known how fast the air was dropping.
After the ordeal, I decided to treat her to some G5 compound and polished up all the glass. It will be one year since purchase in March, I need to give her a full detail. I might do that after my roadtrip.
Also on a positive note, I had a major service due (£600+) but thankfully it had one more stamp in the service plan that the old owner paid for!
There is space over the battery for a spare wheel kit but we didn't get them as an option in the UK. You can pick them up from the dealers although they will be very pricy, keep an eye on eBay though as they do come up every once in a while. I managed to pick one up with the bracket, poly insert and tools for £150 last year. There's one on now but its way more and you don't get all the accessories with it...
Interesting saga. Thanks for sharing in detail.
The TPMS screen is my default LCD screen. I have become rather OC about the evenness of psi, and even obtaining factory psi settings. I never even thought about it before the Stinger. Ha hah.
I'm guessing the 18inch wheel fits as bigger rubber side walls so same diameter as the 19inch wheels? This is a good shout, I need to keep an eye out
Original battery in '20 GT1...decided to get battery monitor from Amazon. Nice features in associated app.
Also grabbed a battery tender (Schumacher)... $19.99 at OSJL!! All set for fitty bucks...
Did the Velossa Tech snorkels today on Big Red (2019 GT2 AWD). Not a difficult job but started out cold in the garage until the heater (and warming outside temps) finally got it bearable.
I just got back from the touchless wand wash, for the second time in an hour. First was the Micro Blue. Second the Silky Silver. I don't usually dry off there. Instead I "race home" - c. half a mile up the road - and dry off in the carport. The one thing I don't have to dry off is the wheels. I did say "race home". Ha hah.
Lots of air grime to get off today. We have an inversion and junky air. And "they" salted the roads a couple of weeks ago, so, it has turned to powder, which I must perforce spray off underneath.
I miss my car 😞
No bro it's getting some mods.
I bring my leaf blower to the touchless. Car holds so much wadder!! Even offered a BJ to a Mustang…accepted!!!
Only my car understands me 😞
