Hey guys, kinda a car noob so sorry if this is basic, I did some research and understand it could be coolant.
Some back story/notes
Has had every oil change on time besides this past one, about 1.5k miles late.
Its around 78 degrees here in NJ
Throughout the winter I had noticed the car would push cold air out with heat on when idle, when driving it would push heat.
I'm driving today, pushed her a little bit maybe 100mph or so, good pulls for about 30 minutes on the way home, pull in driveway and idle for roughly 20 minutes, all of a sudden as I'm pulling out I get a overheat warning and notice the heat is climbing rapidly, I believe though not sure I had the cold air on at the time, Immediately I shut the car off, Google and try to replicate after allowing to cool for a few minutes. I start by driving in comfort around block for maybe 1000 feet, nothing, then I begin driving in sport and do a mini pull too about 3k rpm, nothing still at normal about one away from middle tick on thermo, then I turn air on and it begins rapidly over heating.
At this point I'm panicking, I shut the car off and go to grab food in my other car, about a hour later I come home, open the hood and the engine is somehow HOTTER then it was prior to me shutting it off, I touched prior and it was okay to leave hand on, I come home and it's so f*cking hot. So naturally I say f*ck it, I don't even know what I'm doing but figure out maybe it's the coolant, I open radiator cap and pressurized coolant squirts out in engine bay, i quickly tighten it, clean it up, and then go to look at the white large resquivor on the opposite side, I can't tell if it's full or nothing, but it's still very hot.
I have since leaved it alone and am panicking, can someone knowledgeable please provide me with steps to take to fix this on my own or steps I should take to diagnose the issue, I will learn whatever it takes, I just know I can't afford multiple dealership trips right now.
If it's any help yes I am doing pulls nearly every time I drive, each trip it's pretty much standard I hit 120 at one point or another lol. I will lay off this for now.
