Supra Wheels on Stinger??
very nice! My wheels are done at the machine shop!
I guess I am missing something. What is so special about those wheels, that had you go through all the extra work?
The Center bore is 66.5mm and ours are 67.1. Also the lug pattern is 5x112 vs. ours is 5x114.3.
I had a machine shop open up the CB .6mm
And I will run HPDs “PCD adjusting lugs” for this type of application.
But you didn't say why these wheels are worth all the bother? Ima curious as well. Seems like an enormous hassle, given that you could get trouble-free wheels easily enough.
Really not a big deal to drop them off at the machine shop, and run different lugs…
Wheels machined 00.6mm down from 66.5 to 67.1, then installed extra short TPMS nipples with new sensors, and test fit to the Kia hubs successfully with the HPD nuts, debaged the toyota center caps for now…
tires tomorrow.
Looks great but the lug nuts would worry me
With that spoke design they will be easy to clean always a important thought
That's the thing with black wheels. They all look the same from 10 feet away- invisible. But as long as you like it, that's all that matters.
Yeah I’m typically not a black wheels guy but found these cheap on ebay I wanted to make sure this worked all good before refinishing
That does look really good. How much do the wheels weigh?
RIGHT!! and plenty available out there for CHEAP!
