Interesting report. I suspect low ambient temp might be contributing to that. Ideally, for a spark plug to function well, its center electrode needs to operate in a temp range of 500-950C. The main reason for going to 1 heat range colder plug (compared to OEM plug) is to compensate for a modded car's higher boost pressures
and the higher temps the spark plugs are likely to experience at high engine load (WOT and high engine RPM). Keeping the electrode temp in the proper range prevents pre-ignition, which helps the engine maintain optimum performance.
However... it is possible for the electrode to get too cold (below 500C). That can happen if very low ambient temp causes IAT (intake air temp) to drop very low. That could cause the plug to lose the ability to self clean. In such a case, a colder plug would not work well, especially at low speed and normal driving.
It's a balancing act, and your engine's operating conditions need to be taken into account.
