seeyainakia
- Jan 29, 2022
Just installed new sway bars front and back. Big improvement, love it. They provide a little clamp thing that you're supposed to install ~1/2" from each mount, inside or out. I've never seen this before and just assumed most sway bars were self-centering. I did make every effort to ensure the bar was centered as much as possible before tightening the mounts. Regardless, I installed the clamps as directed, 1/2 inch from each mount on the inside. (in the front, not yet in the back).
After some spirited driving today (hauled ass across a bumpy intersection) I noticed a new sound from the front. After inspection It seems the driver side clamp is now butting up against the mount.
I'm not sure what to do here. There are no visible indicators as to what "center" should be. What is the point of these clamps? How do I know what is center? Should I loosen the clamp and give more distance? If I give too much distance than what is the point of the clamp?
HELP!?!?!?
HELP!?!?!?
