Stiletto
I don't think you mean blowback. If that happens, there are serious issues. Do you mean blow by?even tuned u still get blow back from turbos
Sorry yes this is what I meant I was half asleep lolI don't think you mean blowback. If that happens, there are serious issues. Do you mean blow by?
A step gap ring (turbine seal) is supposed to help prevent blowing oil past the turbine shaft. I went from zero oil consumption to 1qt every 1k-2k miles after changing the primary cats to hfc and deleting the secondary cats.even tuned u still get blow back from turbos
Even still...oil going through to the turbine side is not normal on a factory (albeit tuned) setup. I would think we'd be hearing about thousands of modded Stingers getting oil past the turbo seals.Sorry yes this is what I meant I was half asleep lol
Reading about your situation has me re-thinking the IMR catted pipes I have sitting in my garage. They are the last piece of the exhaust that I would modify. Between the threat of snapping a turbo stud (and having possibly drop the engine to drill it out) and the seals failing, I may just skip the primaries.A step gap ring (turbine seal) is supposed to help prevent blowing oil past the turbine shaft. I went from zero oil consumption to 1qt every 1k-2k miles after changing the primary cats to hfc and deleting the secondary cats.
Looking back on things I should've never removed the primary cats. I guess it created to much of a pressure indifference. Unfortunately, I already sold my oem primary cats for scrap. BIG MISTAKE LOL
Are they 200 or 400 cell? I've heard the 400 cell help prevent blowing oil. I can only share the experience I've had with 200 cell.Reading about your situation has me re-thinking the IMR catted pipes I have sitting in my garage. They are the last piece of the exhaust that I would modify. Between the threat of snapping a turbo stud (and having possibly drop the engine to drill it out) and the seals failing, I may just skip the primaries.
IMR uses 200 cell. UP and NGT are 400 cell.Are they 200 or 400 cell? I've heard the 400 cell help prevent blowing oil. I can only share the experience I've had with 200 cell.
Soak the nuts and studs several times over a few days with PB blaster. That's what I did. I didn't break any. If you start blowing oil put the oem primaries back on. If you choose to go through with it
I agree, those pipes are where the biggest gains are for the exhaust system. But if the stud snaps and they can't drill it out without dropping the engine, it isn't worth the power to me. An 19 hour engine removal is $2k. At that point, I'll just save up for the IMR turbo kit!I have the Ultimate Performance HFC 400 cell and I've had zero issues what so ever. Hoosier has good advice, and you will gain HP. Not so much from the HFC per se, but the stock Primary is choked down to 1 1/2" right where it bolts to the turbo. They are worth it.
Edit...
If I could make one recommendation. If you're in a state or county like me that requires emissions inspection, I HIGHLY recommend these. A Tuned ECU will not pass emissions inspection, so if you put your stock one back in, it will see that there is no cat in the secondary and it will not pass again. Damned if you do, damned if you don't. I threw these in last minute and got the car to pass no issues. I left them in and threw my Sxth ECU back and I was GTG.
View attachment 80456![]()
IMR 45 Degree 02 Sensor Cat for Stinger and G70
IMR now offers tiny cats for your down stream O2 sensors on your primary down pipes! Your sensor detects a cat.... but you don't impede exhaust flow! These have been proven on the IMR shop car for the past six months. The have eliminated engine code P04020 associated with 02 Sensor malfunction...www.imramerica.com
NGT also used 200 cell prior to changing to 400 cell. I have their a set of their 200 cell. The passenger side was actually replaced under warranty. It got clogged and collapsed. I might buy a set of 400 cell to help prevent this from happening again.IMR uses 200 cell. UP and NGT are 400 cell.
I coated them with Aerokroil. My mechanic said the locking nuts are common on turbo flanges and are the reason the studs snap.
One person made a good case concerning exhaust restrictions. The small manifold going from the heads to the turbos can't remove the exhaust gases fast enough. Cramming more in the engine with no where for it to go (hybrid turbos). Back pressure builds and temps climb. Making for a bad situation.
It's unfortunate the hybrid turbos are not reliable - does anyone know their failure mode?
Edit...
My state requires an emission and safety inspection every year. I have catless primaries which will throw a code. Lap3 tune eliminates the CEL and I pass with the tuned ecu installed. I've also passed with Lozic ECU and no primary cat.I have the Ultimate Performance HFC 400 cell and I've had zero issues what so ever. Hoosier has good advice, and you will gain HP. Not so much from the HFC per se, but the stock Primary is choked down to 1 1/2" right where it bolts to the turbo. They are worth it.
Edit...
I remember watching that video when Tork released it. It was super informative.Here's the restriction -- around 3:40 in this video. Supposedly smaller than a quarter (<1")"
I was excited by this chart, and thought downpipes were a no-brainer to remove more of a bottleneck than a catback, but everyone here seemed to think gains were minimal (and the video above indicates the manifold/housing is an even tighter restriction). I don't suppose you have a before/after dyno?
It's a very expensive upgrade. The materials alone for the block will keep shops away.Yeah pretty eye opening that the restriction is that severe, but maybe that's part of what lets it spool at 1400 rpm. I'm surprised there hasn't been more of an effort put into offering a manifold/housing without that restriction.
Is it just too complex a part to do affordably? Even chopping out the narrow section of the stock piece and welding in wider tubing seems like a better route than trying to add a wastegate to vent exhaust ahead of the restriction (vs. sending it through the turbine).
Exhaust manifolds can be had for a couple hundred bucks. Same with turbo housings. What makes this combination manifold-housing so hard to replicate?It's a very expensive upgrade. The materials alone for the block will keep shops away.
From what I understand from speaking with 2 different shops, it's the cost of materials. Apparently, it's much more than a few hundred dollars per customer. I read something a few weeks back on this topic of restriction and cost. I think it was either Nathan from SXTH or Evans from IMR. Unfortunately, I don't remember where I read it. It may have been on FB groups. If I come across it again, I'll post the link.Exhaust manifolds can be had for a couple hundred bucks. Same with turbo housings. What makes this combination manifold-housing so hard to replicate?
