D.J.
2500 Posts Club!
- Feb 24, 2018
- Location
- Toronto, Ontario, Canada
No. Not possible to connect with no power.Mystery solved. I will add a the fuse for the Mando. The only thing is that the MANDO shows "Connected" in the APP. Is it possible to still pick up the bluetooth without the proper fuse in the slot for the ECS10?
...and does this mean the MANDO is not doing what it is supposed to do to the suspension. If I am being honest. I have not noticed much difference.? - E
Sounds like you have power to the ECS10 (green light flashing)
Sounds like you have 1 fuse installed in the add a fuse/fuse tap. That 1 fuse would be powering your ECS10.
And the missing fuse is causing an open circuit to the AFS (module 4).
When you say you didn't notice much of a difference, what program did you select and enable within the Mando SDC ECS phone app?
The default condition is - disabled. You have to connect to the ECS10, AND enable it 1 time.
