ok, I have better questions this round. My new tires were put on the bent stock rims and I would like to continue using those tires. That being said, I do not know the relation between size and clearance regarding the rims, tires, wheel well, brakes, rotors, etc.
2018 AWD GT2.
225/40R19
255/35R19
1. How does tire size relate to the wheel size and do I have to stagger the wheel size? Basically could I put 8.5 on both front and rear with the tires I have and stock set-up? Could I go wider than 8.0/8.5 on both?
2. On Ebay I am seeing listings include the offset. Am I correct in this having something to do with wheel clearance reletive to rotors and calipers?
3. Is there variation or a range in offset or do I have to have the same offset as stock 34/46.5? Does the offset need to be staggered or could I simply buy 4 of the same exact rims?
4. Do I need to consider hub bore size and if I do does it need to be what ever stock is or a range? Why is Hub Bore also listed as "CB"?
5. What would be considered a light wheel?
6. Are Yokohama ADVAN Sport A/S+ good tires in your world?
7. Are there other specifications I need to look at or does anything come to mind as advice?
THANKS guys.
