The car lovers social network
Automotive components
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Lol. Doubtful. I might just have to buy you a beer and you can show me what you did (I'm not handy). HahIf your dealer is different from all the others and is actually willing to do something, please let us all know who it is![]()
I wonder if it's the same dealer I'm going to. They had a stinger in recently for rattling.My car is going back to the dealer on the 16th of December, and they're replacing the sunroof rails. Will update if the new parts help
One or two people a year hit the jackpot and get rails replaced. I doubt it is going to fix the problem long-term since the rails themselves haven't changed.My car is going back to the dealer on the 16th of December, and they're replacing the sunroof rails. Will update if the new parts help
Did the roof rails fix work? My car is currently waiting for new rails in the shopMy car is going back to the dealer on the 16th of December, and they're replacing the sunroof rails. Will update if the new parts help
I gave this method a shot, but unfortunately it didn't make any difference in my case.I would like to share my solution to the sunroof rattle
This is the best solution I've come up with to silence this problem.
1. Open your sunroof
2. Loosen the 3 bolts circled in red and the 1 circled in blue. Do this on both sides (driver and passenger side) Just break the bolts free so the track can move freely don't take the bolts all the way out.
3. Close the sunroof all the way (not tilting) with the bolts loose so the tracks can find their happy place
4. Open the sunroof back up and tighten all the bolts. DO NOT over tighten the bolt circled in blue. The plastic under this bolt will break if you over tighten it. Trust me
5. Now you have completed the process of resetting the tracks that the sunroof rides in. Apply some grease to the rubber seal that I'm pointing at. I used super lube with PTFE.
6. Enjoy the new found silence in your Stinger
I can't guarantee this solution will work for everyone but it worked for me. And I'm not sure how long this solution will last but my sunroof is dead silent now. It's total BS that this has to be done to a car that MSRP's for 55K. But I love my Stinger and I have accepted that I have to take the good with the bad. She requires a little special attention that's all. Good luck to anyone who wants to try this solution.
- Do this at your own risk. I take no responsibility if you damage something -
It's to bad there isn't a fix-all solution to the sunroof rattle issue. Seems like different solutions for different Stingers.I gave this method a shot, but unfortunately it didn't make any difference in my case.
SOLVED?? FINALLY?!?!?!?!?
I plan to try @HoosierStinger's solution, but I'm not holding my breath. If it doesn't work, plan-B is the slightly more invasive proposal from @Marc Collins in another thread...
I can report that my technique has solved all rattles from the sunroof. It is so quiet while driving over rough roads now I can hardly believe it. What it has not done is completely resolve the expansion/contraction issues that are worst when the car has been sitting out in the sun and then the A/C cools the interior causing a rapid mismatch in temperatures. That means there is some other area that the glass is attached to metal or in a metal frame of sorts that is not affected by the cushioning of the rails. The rails are the source of bump-related noises. The creaking/popping from the expansion/contraction is still there...albeit a bit less prominent.I plan to try @HoosierStinger's solution, but I'm not holding my breath. If it doesn't work, plan-B is the slightly more invasive proposal from @Marc Collins in another thread...
you, sir, are a FREAKING GENIUS!I would like to share my solution to the sunroof rattle
I can confirm that this helped in my situation. All I did was loosen the bolts and re-tighten them back to a moderate level instead of the extremely tight from the factory state they were in. In combination with the "sandwich" process linked from the other thread above, I now finally have a sunroof that isn't constantly annoying me when I drive!!! Well done @HoosierStinger!!!I would like to share my solution to the sunroof rattle
That's exactly what KIA is not willing to do....though there are a few isolated cases reported here where they did it and it solved the problem.thanks for this, at least the stinger rattles less than the 72k msrp cadillac cts v-sport I was in. Dealerships were swapping the whole sunroof assemblies for people who complained the most about it.
Same pattern for me, which is why I knew it had to be metal-to-metal contact affected by expansion contraction in the hot weather. Definitely try this!I’ve been following this thread for a couple years. Never fails that my sunroof rattling comes back when it gets really hot in the summer. I always adjust the screws from inside the car the run along the inner edge and move the glass up and down. Not working as well as it used to. Going to have to try to adjust the rails too I guess. So frustrating because I’ve fixed every other rattle I’ve had.
I stole a play out of your book as well. As a extra precaution and it sounds like a great idea. I used microfiber towel pieces with a hole cut in them for the bolt to slide through. Mine doesn't look very pretty but it gets the job done. I only did the passenger side for now. I'll trim down the microfiber pieces someday.I can confirm that this helped in my situation. All I did was loosen the bolts and re-tighten them back to a moderate level instead of the extremely tight from the factory state they were in. In combination with the "sandwich" process linked from the other thread above, I now finally have a sunroof that isn't constantly annoying me when I drive!!! Well done @HoosierStinger!!!
This bolts procedure addresses the metal-on-metal ticking and popping part of the sunroof issues...not rattling. It is affected by expansion and contraction, so unlike some other "solutions" to the problem, this is one has a basis in logic to possibly work. Relaxing the stress points where the metal tracks attach to the metal roof of the car helps. My presumption was that some form of bushing would need to be inserted between the tracks and the roof, but it seems as though just this small difference may be enough to resolve most of the issue. And it is so easy to do, so I recommend to do this first before attempting other fixes, including mine in the other thread.
Unfortunately, my passenger seat now has a vibrating rattle in it caused whenever I traverse a bump. It has probably been there for a while, but I can only now hear it distinctly because the damned roof isn't making constant pops and creaks. Off to search for what the problem might be, but if the seat vibrating (sounds like something inside the seat is making contact with something...metallic.
Happy to hear my solution was beneficial to youthanks for this, at least the stinger rattles less than the 72k msrp cadillac cts v-sport I was in. Dealerships were swapping the whole sunroof assemblies for people who complained the most about it.
Nope no noises from that department lol. Funny that sunroof was quiet coming home from work, I just keep a torx screwdriver in my glovebox aha.Same pattern for me, which is why I knew it had to be metal-to-metal contact affected by expansion contraction in the hot weather. Definitely try this!
P.S., let me know if you had any front seat rattles (probably seat cooling related)!!
