I measured the width ones in inches and it was about 5 inches which if you convert that it is about 127mm which is pretty dam wide lolmeasure the opening in mm and check aliexpress. i'd give yourself at least 5mm on each side to make sure there's a little clearance. you don't want them to actually touch the bumper, they will vibrate and/or melt the diffuser.
so, for example if the opening is 110mm tall and 150mm wide, shoot for tips 100mm tall and 140mm wide. Just using rough numbers here, I don't have a 22 to measure. My tips are 75x105mm and the vendor also sells 95x115mm. Not sure what size the 22 openings are, but those 95x115 are almost an inch taller, so they might fit the bill.
Possibly what site you using to look at these. You have the link?Looks like the second largest would work …
eBay listing - one of the pics … (search Akrapovic oval tip) … not sure if it’s the best place to get them but it’s hard to find them elsewhere. I wish the chrome/cf separation was as obvious as in the round tips but I don’t see any other options other than flat black. About $200 usd for the 4.Possibly what site you using to look at these. You have the link?
That’s actually not to bad, these seem to be more circular than oval so I wonder what size they arePicture I saw in IG before.
I have a ‘22 diffuser that’s awaiting installation and uninstalled OEM tips if you guys would like me to take measurements and photos to offer perspective.If the opening in the diffuser is 5 inches wide I’m guessing the round tips in the photo are the largest Akrapovic tips 114mm (4.4 inches). I guess it’s a matter of opinion but I like the look of the round tips that size even though the diffuser is oval. I haven’t ordered yet because I’m deciding between the oval and round tips. I wish I had a similar pic with a 2022 with the oval tips to better compare …
I’m just cerakoating the OEM tips. Sadly, my Ark catback exhaust exits won’t allow for well positioned aftermarket tips like most of you guys.Sure. What tips are you replacing with? Bring on the pics when you’re done.
thanks,
I have kia Stinger 2018 won't to change my exhuast tip for the 2022 tip anyone know where to buy
Why the discrepancy, though? Why do you believe it is 105mm*130mm versus the 110mm*135mm that guy provided?hey guys! Believe the correct size from AliExpress is 105mm*130mm for oval CF tips. This guy with the tips said his size was 110*135mm and then deleted his comments after. I think he doesn’t want anyone to know so they can sell them for a lot of profit.
Ps. Stock 2022 tip size measurement pictures attached aswell. It’s not my pics.
Because his sizes are almost same size if not bigger than OEM and it would rub, but in his pictures there is a bit of a gap.Why the discrepancy, though? Why do you believe it is 105mm*130mm versus the 110mm*135mm that guy provided?
