TenTwo
- Apr 7, 2021
Here’s the link
Let's call it Rebadged! Looks good!Not exactly debadged but...
View attachment 59139View attachment 59140View attachment 59141View attachment 59142
I've been looking for those, can't find them anywhere in stockHere’s the link
So I am planning to rebadge the exterior. The Front change to the E logo. From what I have seen, its simply a matter of removing the KIA logo, cutting a pin off the new logo and re-applying
On the rear there are 3 sets of badges. I'd like to remove them all and put a larger stinger logo centered on the rear trunk.
Does anyone know if there are any pins in the back 3 sets?
If you take your time to remove OEM Emblems you won't have any issues with your paint, I did my front and had no issues...using a hair dryer and some very thin edged bondo or putty applicators that are soft plastic but somewhat stiff, just go slow and the heat on the emblem itself will soften the tape and it will start to raise up to where you can get it off. There are pins in the front Kia emblem, so just go slow and the results will be fine.I've got the front and rear vintage K adhesive emblems coming as well as the GT emblems for the wheel caps and stinger logo for the steering wheel.
Going to go with adhesive stuff before venturing into activities that could remove paint from the car.
Picking up my powder coated rims tomorrow. Got plastic center caps painted black to go with them.
It's a 4.5inch I believe, with no pins, I got it from Sal at KDM WAREHOUSE, you can contact him directly, as there is one size bigger, 5inch if I'm not mistaken, or 5.5? He initially recommended the larger size but I had already ordered and it was shipped out. I'm happy with the 4.5inch emblem.But the logo you mounted is the exact same size and shape correct? I really like the round all metal one which is smaller if I were going to do a badge swap
To your original question it is a bit smaller than stock.It's a 4.5inch I believe, with no pins, I got it from Sal at KDM WAREHOUSE, you can contact him directly, as there is one size bigger, 5inch if I'm not mistaken, or 5.5? He initially recommended the larger size but I had already ordered and it was shipped out. I'm happy with the 4.5inch emblem.
And steering wheel overlay...There are other colors also.
That's basically what I ordered for both the steering wheel and the wheel caps although I got the stinger logo version for both.
Now I'm stuck waiting for all of the stuff. Still haven't seen my replacements for the rear reflectors that i ordered 3 1/2 weeks ago. Shipping from the US to Canada currently is simply flat out stupid slow.
You already have the sways on...how is it?Unfortunately the USPS is a moving snail out here also and that's even in the same state deliveries and some local shipping, it's gotten horrible! these days. Be patient and it'll get there, good luck man! I'm going to put on my Eibach rear swaybar and subframe bolts and collars tonight, that's supposed to really get rid of that unstable rear end jitters over bad roads when your trying to get on it a little bit and with the body roll, the front swaybar is on its way.
