Stinger4Lifeeee
@Stinger4Lifeeee...Yup, Im AWD.
Looks good man. I intend to do my fronts as well when i lower on H&Rs
Thanks man...just wating to get the springs installed too finish the look!Looks good man. I intend to do my fronts as well when i lower on H&Rs
any reason you wanted to go with H&R instead of Eibach ?
@Gtecko....I went with Eibach...havent installed them yet though. But Stinger4Lifeeee is right about the reverse rake look on some installs,I didnt noticed you were RWD
I have seen Eibach and the drop is more significant than HR, I am mounting my front lip next week and I am told that once dropped on Eibach, it will be quite low in the snow... I am thinking HR would be the same though, thoughts ?
others I've seen you don't notice it as much with the same Eibach springs. I do see the reverse rake right now without the springs on though, so the cars suspension is higher in the front from the get.
No...I've decided to wait on it, till I see how low the front will sit in the winter. But it was why I decided to go with Eibach, knowing it would be a little higher in the front.I see you are in Canada ... so SNOW - do you have a front lip on your car by any chance?
I guess it all depends how much snow you get where you live.No...I've decided to wait on it, till I see how low the front will sit in the winter. But it was why I decided to go with Eibach, knowing it would be a little higher in the front.
Have you noticed any difference in how the steering feels positive or negative since install?@Stinger4Lifeeee...Yup, Im AWD.
Good luck with the spring install! I just did Eibach springs on mine by myself took me maybe 10 hours. (I don't have experience with springs) but it turned out looking good. Thinking about doing the spacers now.Thanks man...just wating to get the springs installed too finish the look!
I will wait for some of your picture once installedThanks
@Gtecko...Finally got the time to install the springs. It doesn't seem to low for a lip in the winter, but I think i'll go through one before I decide to install any type of lip, just in case.
that looks great !!
which springs did you go with again ?
is this after the alignment ?
did you end up doing it yourself ?
They're the Eibach lowering springs with 20mm spacers. I still have to do the alignment, but I'm pretty sure it's mostly for tire wear, because the car drives the same. no pulling to one side or the other. Got a mechanic friend of mine to do it. With a hoist it's pretty much easy...he got it done in just under 2hrs.
