Killer Time congrats !
Im curious what are the
EWG wires doing for the 0-60 by themselves ? I could never get a straight answer to weather or not the
EWG wire do anything for power on this car.
Unfortunately, I did not measure a back to back difference after only adding the
EWG connectors. But, I would say that the connectors make a noticeable difference. Again, prior to using them my logs showed only hitting 17 psi in 1st, 18 psi in 2nd, and finally 20 psi in 3rd. With the
EWG connectors I'm hitting 20 psi in 1st and 2nd like I'm supposed to. That said, if you're running WMI I DEFINITELY recommend the
EWG connectors.
EWG and WMI help up top. Stock WG is 50, you can adjust duty bias for upper rpm starting at say 5,500 +3, which would be 53 for 5500 and 6000; +2 (52) for 6500. The rest are 50's and start with the included settings in the instructions.
While the
EWG connection is very nice in that it allows boost adjustments in 500 rpm increments, allowing increased boost in higher rpms, I must say that it improves spool time as well - that is, it effectively improves power all around, not just up top. With FF and Duty Bias settings all set at 50 I not only felt the turbos kick in harder, but like I said above it actually reached peak boost faster, allowing me to see 20 psi in 1st and 2nd gears whereas before I couldn't... Keep in mind, this is all before even increasing duty bias.
Of course this all depends on your boost targets. That said, if you're running something like Map 2, I don't think the improvement will be very noticeable (though I'm sure it will still help a tiny bit).
I just wish Terry would enable a way to build boost during launch control with the
EWG control. I don't want to hash up my ECU/brake pedal harness for the brake snip. In theory we should just be able to close the wastegates a little during launch control.
