WildBill
Yes you are correct. I initially tapped the front door speakers thinking that they were full range. They are not. They have a high pass filter applied. The subs obviously have a low pass filter which you would have no adjustment over.
There are devices that can combine the signal from multiple high level inputs to create full range, which you can later break back down as you wish. Again, too complicated and expensive for me.
