I did plugs yesterday myself. Denso IKH27
Did you had to take off the manifold to replace the trouble spark plugs or just use the trick that combine angel tool to get the passenger side plugs off. I want to change my plugs, but too afraid to message with the engine at the moment. I know there been several video on how to change it on YouTube, but watching is one thing, doing it is another.
When are you coming to Florida for VacationI didn't have to take the manifold to take the trouble plugs out, but I chose to change all of my plugs and take the manifold off because I wanted to look inside the manifold to inspect my air valves.
Johnni if you were local I would do it for you for free and teach how to do it. You can do this bro just watch this video and take your time. If I became an engineer being a borderline idiot, anything is possible. I did this video 2 days ago. I also have a video doing the spark plugs without removing the manifold. Removing the manifold is easier if you are beginner and don't have that many tools.
If you need the instructions from Kia, send me a PM and I can send those to you.
I did this video just for you LOL JK
If you have any questions feel free to contact me.
Angel
When are you coming to Florida for Vacation![]()
Good job Angel. Thx for doing that. CheersI didn't have to take the manifold to take the trouble plugs out, but I chose to change all of my plugs and take the manifold off because I wanted to look inside the manifold to inspect my air valves.
Angel
Tampa about 1.5hr I go to Disney all the timeLOL believe or not I go every year to visit my wife family (Mother in law, brother in law etc.) They all live in Florida I also have family myself in Florida, my brother, Aunt and cousins in the Orlando Area.
I am going to Orlando next summer. If you need me then I can talk (Get permission) to the wife and help a brother out lol.
What part of Florida? How close from Orlando/Kissimmee area?
Out of curiosity why did you have to remove brake fluid before you swap rotors and pads? I've never heard of that before and done plenty of rotor/pad jobs over the years.No pix yet, but I upgraded to slotted and drilled rotors w/ceramic pads.......it's a driveway job, 1st thing I did was remove a few ounces from the brake fluid reservoir(red plastic screen requires a special tool which I did not have).....I'll need another one of those....so will you. then it was simply doing one wheel at a time. The main point of this post is rust. There was quite a bit built up between the rotor and axle housing(s)...everything got a dose of neverseize before reinstalling the rotors. Follow the break in procedure after topping off the reservoir and it's an easy job.....brake performance had the rotors and pads with quick delivery props to them.....all told 457.00$ but I have better brakes now then before.
when upgrading, the pads were a bit thicker, so when you compress the piston the fluid displaced will not overflow out the reservoir. a few pix.Out of curiosity why did you have to remove brake fluid before you swap rotors and pads? I've never heard of that before and done plenty of rotor/pad jobs over the years.
Great job .................are you going to paint the calipers ?? Red to match the GTs ??when upgrading, the pads were a bit thicker, so when you compress the piston the fluid displaced will not overflow out the reservoir. a few pix.View attachment 25215 View attachment 25216
I grabbed a silver capped can of extreme heat at napa....sumbitch was filled with copper paint......soooooo copper it is.Great job .................are you going to paint the rotors ?? Red to match the GTs ??
DUH ! Yes correct , I'll edit that , thanks ...............brain fart ...........................You mean the calipers, right?
You said "PADS", before the edit; am I right about that?DUH ! Yes correct , I'll edit that , thanks ...............brain fart ...........................
no they ended up copper.....I can always repaint but it will be silver when/if that happens.Great job .................are you going to paint the calipers ?? Red to match the GTs ??
