Can you please confirm which one I need to grind down? Is it the same as the American video showing you?Depends where you got them from. I got mine from the forum shop and the one that needs to be taken off was already off
I should be the bottom post, a little hint, using a good quality pair of side cutters gently grasp the post as close to the tape as possible then with minimum pressure rotate the side cutters around the circumference of the post until it “wears” through, then using a twist drill that is slightly larger in diameter as the post carefully drill the remainder of the post down so it is well below the level of the tape, this then should not touch your bodywork once it is applied.Can you please confirm which one I need to grind down? Is it the same as the American video showing you?
Ok gonna be tough because I'm giving to the dealer to do hahaI should be the bottom post, a little hint, using a good quality pair of side cutters gently grasp the post as close to the tape as possible then with minimum pressure rotate the side cutters around the circumference of the post until it “wears” through, then using a twist drill that is slightly larger in diameter as the post carefully drill the remainder of the post down so it is well below the level of the tape, this then should not touch your bodywork once it is applied.
Also another hint, before peeling the adhesive backing off test fit badge to car to ensure the “E” is level, if not file a flat on the bottom appropriate post until level.
You must have small hands...lol, it should be Diameter 77mm with a slight curve to match the front panel.Is it just me or is this front badge huge?
But my stuff has arrived yayView attachment 20546
Haha ok just seems a lot bigger than I imagined (that's what she said)You must have small hands...lol, it should be Diameter 77mm with a slight curve to match the front panel.
Nice loot, where did you buy the LED reflectors from & how much, Ive been eyeing a set of these myself, what’s the initial quality like.?
Is your dealer installing these as well?
$365 for reflectors and quality feels very goodHaha ok just seems a lot bigger than I imagined (that's what she said)
I got everything you see there for 500 delivered from America I think...quite expensive and I know I paid a premium for the badges but didn't know about this forum shop when I ordered.
I'm getting an auto electrician to install for 70 bucks.
Is that AU$365 delivered? & what store in the US was that from?$365 for reflectors and quality feels very good
Shop has all 3 removed....Can’t remember now, and it’s stuck to the car so can’t check lol. Have a look in the shop section of the forum there’s pics of the badge with the pin removed
Yes it is and k8stingerstore.comIs that AU$365 delivered? & what store in the US was that from?
Thanks, did you get the standard or sequential type?Yes it is and k8stingerstore.com
Sequential of courseThanks, did you get the standard or sequential type?
 be careful not to order the wrong one. I didn't realise it was a selection...had to get refunded and reorder right one.
 be careful not to order the wrong one. I didn't realise it was a selection...had to get refunded and reorder right one.Yes, I would go sequential as well, keep me posted please on the install & functionality of them.Sequential of coursebe careful not to order the wrong one. I didn't realise it was a selection...had to get refunded and reorder right one.
Yes I would remove the post myself to ensure it is done to my satisfaction & the knowledge that the remainder of the post isn’t hard up against the paintwork.Ok gonna be tough because I'm giving to the dealer to do haha
Accidentally started taking off wrong oneYes I would remove the post myself to ensure it is done to my satisfaction & the knowledge that the remainder of the post isn’t hard up against the paintwork.
Ouch, don’t quash too hard you still need to pick up the small hole in the centre so you can drill it down.Accidentally started taking off wrong one
Too late haha whoops....borrowing neighbours DremelOuch, don’t quash too hard you still need to pick up the small hole in the centre so you can drill it down.
